Perform this procedure to configure PIM and IGMP Snooping in an SMLT environment. The
configuration steps show how to enable multicast, and then configure the usual PIM and
IGMP Snooping related VLANs and global attributes. It includes steps to configure the
following:
SPBM must not be enabled on the vIST peers or any router participating
in the PIM network.
In the navigation pane, expand
Select the Boot Config
tab.
Clear EnableSpbmConfigMode to disable the boot flag.
The system responds with these messages:
Warning: Please
save the configuration and reboot the switch for this to take
effect.
Warning: Please
carefully save your configuration file before rebooting the switch.
Saving configuration file when spbm-config-mode is changed to disable,
removes SPBM configurations from the configuration
file.
Select Apply.
- Save the configuration,
and then reboot the switch.
Important
Any change to EnableSpbmConfigMode requires a reboot for the change
to take effect.
Configure the SMLT MLT:
Expand .
Select the MultiLink/LACP
Trunks tab.
Select Insert.
In Id, type
the ID number of the MLT.
In PortMembers, select the ellipsis (...).
In the Port Editor:
PortMembers dialog box, select the desired ports.
Select Ok
Select Insert.
Configure the vIST MLT:
Repeat steps 6a to 6g to
configure the MLT.
Select MltVistEnable to enable Simplified vIST.
MltVistEnable enables Simplified vIST and is
only available when the EnableSpbmConfigMode boot flag is disabled.
Select Insert.
Create the vIST VLAN:
Expand
In Basic,
select Insert.
In Id, enter
an unused VLAN ID, or use the ID provided.
In MstpInstance, select the down arrow, and then choose an
MSTI instance from the list.
In Type,
select byPort.
Select OK.
Select Insert.
Select the vIST VLAN
from the list of VLANs, and then select IP.
Select Insert.
Configure the IP address
for the vIST VLAN.
Repeat Step 8 to create an SMLT
VLAN and assign the SMLT MLT ID to it; do not use the vIST MLT ID.
Configure PIM or IGMP Snooping
on the SMLT VLAN:
To enable PIM, select
the SMLT VLAN from the list of VLANs and select . Select Enable
and select Apply.
To enable IGMP Snooping,
select the SMLT VLAN from the list of VLANs and select . Select SnoopEnable and select Apply.
Configure PIM on the SMLT
VLAN:
and select Apply.
Select to enable PIM globally.
Select Enable, and then
select Apply.
